- Oct 7, 2020
- 2,441
I'm not sure where this needs to go, has nothing to do with machining.
I have hand full of air pressure gauges and they all seem to read a little different. Checking the air pressure on a water well pressure tank yesterday I decided that I would compare a couple of gauges. Now here is the weird thing, my tire pressure gauge that's attached to an air hose I use as a reference. I checked a couple other gauges on my little air tank, and they are close but when checking the air pressure on the pressure tank which should be 38 psi with no water. I got 38 psi with the tire gauge, but 1st try with a little digital gauge I got 32 psi, rechecked with my little tank the two were very close, back to the pressure tank tire gauge 38 psi, digital 35. WTH
I thought of what the reason might be as I was typing this. On the pressure tank I noticed that it seems to be a little slow coming up to pressure. Maybe the orifice on Schrader valve is blocked a little and the digital gauge takes a reading at say 1 second or less and doesn't read the full pressure.
Thanks for the help! I think I got. LOL
I have another question. Do you guys have any recommendations on a good air pressure gauge?
