So I got an air compressor at an auction for probably too much money and it makes a weird resonating sound.
It is a California air 9010d and it has an air dryer built in, which is why I bought it. I couldn't test it because the pressure regulator switch and gauges were broken, I'm guessing it got knocked over and broken. I've replaced that but now I have the weird sound issue.
The sound only occurs when it is building pressure into the tank. In the video it only happens after a few seconds of the motor spinning, I think this is because the electric solenoid is open at startup and closes after a second. I've tested it every way I could think of to isolate the sound. It still happens with just the compressor unit plumbed directly into the tank so I am confident it either the compressor unit, check valve and solenoid switch, or the tank itself.
Has anyone seen anything like this? My current ideas are the oil-less pistons and cylinders are worn and are resonating when under load building pressure, or the check valve is faulty somehow, or the air going into the tank is causing the resonating. Its hard to tell where the sound originates from because the tank just amplifies everything.
Does this actually matter? Probably not because I don't think it will explode, but I would like an ultra-quiet compressor to be ultra-quiet, and not a musical instrument.
