got what I thought was a pretty good deal on a twin cylinder 60 gallon air compressor
(150.00)..the po had it hooked up to power and noted that there was some sort of valve issue with 1 cyl as it would not reach full pressure and intake had air coming out .. other cyl seemed fine..
I took the head off and found one obvious problem.. the aluminum head gasket was cracked... problem was where to find one...this is an approx. 8 yr old made in china pos ...
I got some 0.006 al shim stock and went to work with emachine shop..and d2nc to produce the gocde.
I started with a piece of 1/4 in al stock, squared it up and cleaned up both sides.
I clamped 2 pieces of shim stock between the plate and a piece of mdf to my table and then used the same 3/16 in end mill to cut the pattern and then drill out the holes for the head bolts.
the last step was just trimming some of the excess off and installing...
rich
rich
