- Jan 6, 2017
- 1,242
About 2 weeks ago I decided to replace the 8 year old filter elements in my air compressors intake filters. When I had them apart, i noticed that the cheap stamped sheetmetal housings were pretty beat up, so I decided to replace them.
Searching for replacements online and reading reviews started me down the rabbit hole of looking for better quality, quieter designs. Naturally, the designs with the better reviews were alot more expensive, like the Solberg ps-10-050.
I modeled, 3d printed and tried about 10 different iterations of several designs, and most were pretty loud. Most were louder than the cheap, stamped sheetmetal units that came with the compressor pump.
The quietest of all of them, will keeping the airflow above the 16cfm rating of my 7hp v4 pump was this twisted pentagon, with a kinda tapered helical path of the air inlet paths. The idea behind this design was that the sound waves following a curved path would be forced to interact more with the rough 3d printed surface finish, and maybe attenuate more per distance traveled.
It seem to have worked, since it's actually the only one of all the designs i tried that is actually quiter than the oem housings.
View attachment 504215View attachment 504216View attachment 504217View attachment 504218View attachment 504219View attachment 504220
The last prototype worked well, but needs a better seal between the lid and the housing, so I added 5 screw holes at some sockets for threaded inserts.
The final version will look like this:
