bicycle rear hub.
so, lathe, or bore with the boring bar in the mill? i want to open the bearing diameters out a couple of mm to accept a readily available decent sized standard cartridge bearing, instead of the angular contact ones which it currently runs. i will have to make a centre crush tube as well to space the inner races.
i am wondering about the best way to hold it - i am currently favouring clamping it on the mill, clocking up the bore, and boring it out, then turn it over and repeat. if i did it in the lathe i think i would struggle to hold it properly.
what do we think?
Jamie
edit add, probably clamp it into a v block on its side, using one of the flat machined surfaces to get it perpendicular to the bed?
