I'm exploring the use of rhombic shaped inserts for use in tight spaces with softer materials, particularly delrin, acrylic resins, ebonite but possibly also aluminum. The real issue here is tight spaces... I already have the Shars extended live center and an Aloris extended holder, but my work is small and getting smaller as I get more skilled, and I don't always have the luxury of cutting a relief groove to get started. Further, my experience with carbide inserts to date has all been with CCMT and CCGT, so I'm pretty comfortable with 7 deg relief, have not used any negative or zero relief inserts. Thus, I'm thinking of trying VCMT, VBGT, or VBMT.
Further, what would be the correct holder for one of these? The Black Book (3rd edition p. 199) has the SV series, and from the directional arrows it appears that SVVC might give me the most flexibility. Have I thought this through correctly?
Finally, assuming for the moment that this logic is OK, I'd love to hear your experience in purchasing this holder and inserts, which I realize will probably not be cheap since it's not seen all the time.
Alternately, and to anticipate Mike's inevitable response, since I am an adherent to his HSS method and have successful made my own square, threading, and zero rake tools, I'd love to hear if the long tight angle is workable in a grinder. I'm certainly willing to go that route. Would a longer threading tool shape work?
For context, although I'm teaching myself the basic skills and practicing mostly on 12L14, moving progressively smaller, my real use will be fabricating replacement parts for vintage fountain pens, which generally run in the size range of OD .200"-.250" and are often as thin as I can get them. Tolerances are pretty big, though, in the .0010-.020 range since the material expands and shrinks a bit and the old parts they fit on or into is often a bit wonky. So I'm looking at a lot of close-to-chuck work with short lengths.
My lathe is a Logan 820 with AXA tooling.
Many thanks!
Tim
PS: I just noticed that LMS has an AR Warner kit, Warner's kit #16, with VCMW and VCMT 7 deg relief inserts and appropriate L and R bars that aren't specified by its name. The set is $139 and individual inserts are $10, which would certainly be affordable. Would that work?
Many thanks!
Tim
