I am looking at making a few bottle openers out of some inert .50 BMG rounds and I am looking for some suggestions from my H-M buds. Before anyone gets started I have had these reloaded by a friend with no powder or primers so they have a hole in the bottom and can’t go boom ever again. Also the one in the vice is just the example that I am copying and it is not how I plan on really holding it for machining. I am thinking of reaming a piece of square stock with a .50 chamber reamer to hold them in the vice. This is hard brass and I half way tried to slot one of the empty cases with a 3/8 four flute HSS Hertal end mill just to se what would happen. What would happen is it will grab the far side as it passes through and fling it across the shop. I said half way because I was turning a little slow (1000 rpm) and did hog it a smudge thinking “it’s just brass”. Mostly messing around one evening.
I am not posting this in the gunsmith section because it a bottle opener made from a inert round.
