My daughter and I are machining the parts for the Metal Lathe Accessories Die Filer from a casting kit MLA-18. There are several holes that are created for brass bearings that I hope to press fit later. We used the boring bar for the first time ever today and the surface finish is a nice neat spiral. When we stopped today, we were at 1.190in. of the final hole diameter of 1.250 in.
So my question is: When I am press fitting in a brass bearing into a 1.250 in. cast iron hole should the surface finish be polished, machined smooth, or is the grooved boring bar finish the goal?
