Advancement in welding of 7075
Probably not a game changer. 7075 is usually used in applications where it's high strength is needed and welded aluminum is not as strong as unwelded, so probably won't make a huge difference for most applications. Would be helpful for molds, but they already weld those, they just let them crack. I can't see an aircraft flight certification authority allowing this without a mountain of data. Castings (of any metal) are usually a non starter on some aircraft just because of the strength hit you take from the variability of the casting process.
