- Feb 27, 2022
- 18
I hope I can get some help with my 6913 lathe. I am rebuilding the apron( and almost everything else) in my Clausing. In the apron the Pinion clutch assembly has been messed with by the previous owner so I would like to know how to adjust the clutch. When I got it torn apart I noticed the balls were not visible through the holes in the plates. So I took the assembly apart and lined up the balls with the holes but I did not know how to set the tension adjustment on the plates. This has a nut with a locking washer that secures the nut in the proper position. I am sorry if this does not make since, but it hard to explain. Has anybody out there have any knowledge about this part?
Thanks
Thanks
