I'm hoping someone here can give me some advice on how to adjust what I've learned are "parallel gibs". I understand adjusting tapered gibs but when I took this mill apart to clean out 50 years of grease pushed through the machine I discovered that it uses this system.
It's a US Machine Tool "V2" mill. There are no external gib adjusting screws on the outside. The gib itself (X axis) is attached by two screws with lock washers from above (with table removed.) There are some shims in there and I just left them the way they were.
In the pictures I've attached you can see there is uneven wear from where the gib rides vs where just the table rides. This doesn't look right to me. There is a wiper retainer that was removed to take the pictures. From the right side of the saddle you can lock it down with the lever shown in the pics.
Can anyone give some useful tips on how to adjust this properly to assure even wear?
I am, at best, a hobbyist, at worst, I know just enough to be dangerous.....
Thanks in advance for any help!
