Adjusting Blade Tension on the FEMI 780/783 Bandsaw
Micke S
Oct 9, 2014
465
It is important to apply good band tension to a bandsaw to make it cut nice and not to get premature blade wear. I did the following to get a reproducible method.
  • Checked how much the blade stretched when I turned the adjuster to more than a reasonable tension. This gave a blade stretch of just over a thou, 0.03 mm
  • Reduced the blade tension to what I felt is quite hard but not too hard. This resulted in a stretch of 0.8 thou, 0.02 mm
  • Replaced the adjuster knob with a M8 nut and a large and thick washer
  • Checked what torque that gives 0.8 thou. This was 15 Nm, which will the torque to use each time the blade is stretched
:thumbsup:
bra tänkande,
bladspänning är mycket viktigt för rak sågning och blad livslängd.
Jag är säker på andra kommer att följa din bly.
tack.
mike:))
Thick wall steel tube cutting. A 10 lbs weight is attached to the handle to get a strong and defined pressure.
the saw cut through the tube like it was butter!!!
great work!!!
