The function bar has a total of six square slots. Theoretically, six position restriction modules can be used. After much consideration, I decided to use only five, leaving the only one in neutral, which can slide freely when there is no need for stage cutting
The story behind it is very bumpy, I designed 3 versions before and after, made 10 in total, and then only published the final successful sample photos.
