Adapting 16 inch colchester 3 jaw for my hb 575 CAZENUEVE
stuarth44
H-M Supporter - Gold Member
Jan 22, 2020
197
No chucks for the CAZENUEVE were readily available so TURNER PRECISION in Kunda Park gave me, for 300 dollars this 3000 Steel with bevel gearing , then I had to bore out the chuck back to fit my caz mounting faceplate, I used a very old fashioned calliper and cut a brass rod to fit that and crept up to the target 320mm, my Mitutoyo verniers stop at 300, but I was happy to hit the target, and pressed it home using the powerful tailstock feed, chuck weight 90kg, plus abt 25 for *caz mountings, my old 3 jaw was stuffed, back of the 1 -8 D camlock is fine grained cast iron held onto the chuck body by 6 9/16 fallen head screws
