- Jan 6, 2017
- 1,245
But, I got it done. Finally!
Anyone else done something like this? If so, how did you do it?
I picked up a Helmke Plus 3hp 3 phase motor on ebay. It was 200$ with free shipping from Germany. Kinda baffling that they could sell a 40lb motor, and ship it from Europe for that price. Oh, and it only took 5 days to get here.
It has a standard 100l b5 frame and 28mm shaft, so I hand do do alot of work to fit it to the PM935ts. Including boring the pulley and broaching a new keyway.
I had to fill in 2 bolt holes, and build up alot of metal with a Tig welder to create the two 1/2-13" threaded holes needed. Welding cast aluminum kinda sucks, and I got plenty of porosity.
On the right side, I had to make a new bracket/mount and belt tensioning lever. I ended up using a scrap stump from a Krieger 5r .30 barrel, turned threaded and knurled to use as a lever.
This job was kinda tough. But it's finally done. I got to use it for a few hours yesterday to make some lead molds for a local company that makes leather saps. It seems to work great, so far.
With the vfd set to a 25hz min and 75hz max, between the step pulleys, back gear and variable speed motor I have a speed range from 8 rpm up to 3600rpm.
