- Oct 27, 2013
- 124
I had time to fiddle with my Y axis encoder cable (ACURITE 5). Got it to work (happy) by straightening the bent prongs that had been torn from the plug (previous owner or the move). Then randomly plugged the broken off metal 6 pin part into the crushed plastic/bakelite portion of the cannon plug until i got it to read! If I hold it tightly it reads, but I cant do that and run the machine so it needs to be fixed.
The cable from the position sensor is armored. With enough forensics I might be able to solder up new connections, maybe even directly to a new serial plug. I worry that I wont be able to cut the armor and still know which wire is which. Ever had one apart? Are they color coded? How many wires does it take to send the signal?
For some reason the armor cable ends as a 6 pin round cannon plug, then a 12" adapter cable converts back to a serial style plug that goes into the back of the readout. I'm thinking it's been repaired before. Sorry not the best photos
