I want to tap a piece of mild steel, or maybe 12L14, about 1/2" thick, a through-hole, acme 7/8-6 thread pitch.
Taps for this pitch seem to fall into two camps: $15-$25, and $150+. Since I only need to tap one hole, I'm inclined to go with a less expensive one.
Any experience with these taps?
Also, what size bit is recommended for this size bolt? A standard tap drill chart shows 7/8-9 uses a 51/64" bit, not sure if that's close enough for acme 7/8-6.
Thank you.
Thank you.
