- Sep 20, 2012
- 560
I think there is a thread about doing this on here but can't find it, If anyone knows where it is, would they be kind enough to post a link in this thread?
Having read about the Delrin method of making new nuts I thought I'd give it a go, as I had a lump of Acetal handy, my first attempt had alignment issues..
My second idea was to drill the hole, hacksaw the block in half, but stop the cut at a point which would leave the spigot part whole. Then I wound the screw in which forced the halves apart, I was much more careful with the heat this time and it was successful. I used a spare worn screw.
After the melting and taking it off the screw, I tapped a knife into the cut to open it, then used the screw with a ground flat on the first thread to clean the thread so that is turned the full length easily.
Using a tight fitting drill for alignment I turned the sides and end face to be square with the screw.
Only very slightly loosening two jaws, I swapped ends it in the chuck, I drilled and tapped the center, I drilled right into the lead screw hole as I wanted to use a much longer fixing screw as I didn't thrust the spigot not to snap off, this way it is just a spacer.
I put a screw in the hole before turning the spigot to stiffen it and avoid flexing, I thought had hacksawed too far but you can see there was just enough uncut left if I made the spigot a tad longer than the original one, more careful measuring here is the only thing I will do differently when I make another for my turret slide.
Two holes then drilled for self tappers, I opened up the top part for clearance, putting a hack saw blade in the slot as a stop to prevent drilling into the bottom half, and countersunk them.
Rounded off the end with an angle grinder and finished it by hand filing.
It only took a morning and I now have absolutely zero backlash!
It works OK dry but with lube it's silky smooth...way to go guys, get it done!!!
Bernard
Bernard
