thanks! just finished using it to tap the giant T-nut I made for my new lathe tool post. the one that came with the tool post was way too small. I have nice US made metric and SAE tap sets, but they only go up to 1/2" and 13mm. this was 3/4-16. did a little cold bluing after I tapped it. so far I haven't run into anything with British threads.UNF & UNC, Very nice! Bet you will find a use or two for those in the future..
Most of my Taps and dies are BSCy. The only other Taps and Dies are metric for this darned 7x lathe I am rebuilding where I neet to tap holes or make specific fasteners.
You need to buy/bid on some job-lot "engineer tools" lots on eBay. They're almost always rammed with taps and dies, plus the odd nice items that makes them worth buying/bidding.UNF & UNC, Very nice! Bet you will find a use or two for those in the future..
Yes, carbon steel; use on stainless will ruin the tool in possibly one use.Like most Hanson's they are most likely high carbon , not HSS . Still a nice set , I have a smaller Ace set somewhere around in the dungeon .
most likely. but the 3/4" tap and die cut that big tool post bolt like butter this morning. besides threading the new T-nut, I had to lengthen the threads on the bottom of the bolt as the new nut was quite a bit thicker. the die worked as well as the tap. I spent 2 hours this afternoon cleaning everything and coating everything in Boeshield, as I always do.Like most Hanson's they are most likely high carbon , not HSS . Still a nice set , I have a smaller Ace set somewhere around in the dungeon .
