Hello. I have a problem with my bench top drill press. I make folding knives and need to drill very small and accurate holes from 0-80 size up to 1/4 inch. I've found that the drill press I'm currently using is within a couple thousands at the top of the stroke, (with a $100.00) keyless chuck, but when the
spindle is moved down to drill the accuracy goes to crap. Lots of spindle play and the cheap jam screw on the side has such corse threads that the slop
cannot be taken out with binding the quill.
My question is: I'm looking for an accurate drill press in the up to $300.00 or so range..........any suggestions? Speeds arent a consideration, as this would be a dedicated to knifemaking machine, I have a floor model grizzly for the bigger stuff.
Thanks
Kevin.
Thanks
Kevin.
