Accuracy is fun
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
8,666
Remember when you couldn’t hit your goal to save your life?
A good friend is restoring a 1967 Ford Bronco. I mean from the frame up.
He asked me if I could make him a transfer case linkage bushing.
I said, be glad to.
We decided what we needed.
I’m using scrap tie rod end material. Keeping it Ford all the way.
I hit my numbers. That’s the fun part.
You did a really good job on that part, Jeff!
On the money Jeff!
I’ve been on a kick to try to hit dimensions exactly, too, even when it’s completely unnecessary. It’s a great learning experience to miss a dimension and then work backward to see how the miss happened. And still surprising when it works.
Joe Pie has a great video where he makes a run of parts with a seemingly reasonable setup, has wild variances, then shows why the setup failed. That was very instructive for me.
My friend with an auto repair shop called, his employee lost a bushing for an idler belt tensioner. PFFFT done, tapered step, and all, yeah we're good Jeff.... Not me but I'm able to help if I can :grin:
