AC tig welding
Boltthrower771
Nov 24, 2011
1
I have a Miller Dialarc 250 AC/DC welding machine. I recently got a high frequency arc stabilizer box model 115-007. Im am not sure of the make of the stabilizer box, but through a little research, I believe I have a century product. My question is; will I be able to tig weld aluminum with high frequency( or pilot arc)? I am a little confused about the whole AC high frequency tig welding setup. Either way I can still scratch start my tig for mild and stainless DC welding. Any suggestions. Boltthrower771
In short, it should work just fine for AC welding Aluminum. Run the HF on continous. You'll find that it takes a lot of current to weld aluminum. Another thing to be careful of is that aluminum is a very good conductor of heat, and it can hold a lot of heat. If you've been welding on something, don't pick up the far end thinking it should be cool, it won't be. :)
