Here is the bracket fitted to our ute and almost ready to be finalized. Just need to remove the masking tape and use some anti sieze on the stainless steel bolts. Putting the nut and washer up into location was fiddly. So I used super glue to glue the washer to the nut - that way I only had to juggle one thing rather than two. Have never done that before and it worked a treat.
