I have one similar, that I used full Alum angle then also took the Alum angle and attached it like you did. Also adjusted it so I had some wide areas for things like boaring bar holders, and my holder with my gage mounted in it, etc. Makes it a little heavier but figured it would hold up. Problem is it fills up to quick may have to redo it a put them a little closer together or make it a double row.
