A pair of Machinists's Clamps and a dose of humility.
David Kirtley
Dec 17, 2012
630
Well I finally finished the clamps I have been working on. I started out with 1/2 in square and 1/2 in round 12L14. I cut the angles on the jaws at 10 degrees. I started at 20 degrees but it looked too steep at this size.
Then I started working on the screws. These are 1/4-20 with a bit of knurling on the top for grip. I got them roughed out first to get them all the same size while I had all the measurements fresh in my mind.
Last night I finished up the screws and tonight I started working on the jaws. Of course when I drilled the jaws, I knew to be careful and make sure to get the correct sides tapped and the other side drilled for clearance. What did I do? Of course I drilled a clearance hole on the side that was supposed to be tapped. While I had all the stops set up on the vise, I grabbed another piece of 1/2 in square to make a new jaw. This time I got it right. Then I swapped out the drill chuck for an end mill to create a pocket for the retainer E-clip on both jaws. As I put things together, I realized I had put the pocket on both jaws of one clamp instead of one for each. Oh well. I just have a bit more clearance on that clamp. :) Once I had them together, I marked the retained screw to turn a notch in the screws for the E-clip. Then with the one screw holding the halves together, I trimmed the jaws front and back to make them flush. A little light file work to deburr but I left them fairly plain. These will be used and I will have to file them every once in a while as the 12L14 will dent a bit as it is soft. This was by design. I don't want them scratching up stuff that is clamped together.
The finished clamps:
A close up of the retainer clip:
I was really glad I picked up one of the 300 piece assortments of E-clips up at Harbor Freight. It was too good of a bargain at $3.00 to pass up.
I thought about cross drilling the knobs for a crossbar but I decided that if I needed to clamp something that tight, I would be better off using a different kind of clamp.
Good job!
I have one old machinist clamp. It gets used a lot. Good choice of project.
Walt
Nice project! I've had a couple of those on my to do list for a while now, along with a dozen or so other things. One of these days I'll get some of these made too.
Great work.
For all the disappointments in Harbor Freight(we call it the Chinese Tool Store down here) they have many redeeming qualities,like the kits with E-clips,o rings,hair clips set screws and such. You will loose the small parts or need one for a new project and spend large quantities of time going to a hardware store or have the cheap HF kit on hand and just go get what you need.
Isn't 12L14 fun material? I try to keep 5/16 to 3/4" round on hand at all times. BTW, it will harden quite well with Casenit/Cherry Red. They wear quite well when hardened. I keep 1144 (Stressproof) on hand too. 90% of my repair parts are made from these materials. I have accesslocaly to almost any other material as needed. This part of Texas is oilfield related and we have machine shops and supplys galore.
I am blessed.
