- Aug 22, 2012
- 4,273
Well almost.
I have mentioned before how I use WD40 on the file when filing aluminium as an aid to prevent the inevitable pinning but thought I would do so again with a couple of pictures showing the finish thats easy to achieve.
I use a file that Nicholson call a MagiCut but in this instance I'm using a cheap Trojan file with the same cut.
This is the file and the job, 3 small brackets that were rough cut with an angle grinder.
This is the result showing the sort of pinning that can occur with a dry file, nowhere as bad as a conventional file but still very annoying.
Now spray the same file with WD40 and you can get an almost mirror finish with a lot of material removal at the same time.
As the file loads up a quick brush with a wire brush along the teeth and your ready to go again.
