I was confused, I thought you welded an upright by the wheel, and then the finished project was the orange bed without it. I thought you made another, but I guess you didn't weld the upright on.
I originally planned to use only one pillar, because the actual use feels thin, so I will add another pillar in these days to enhance the strength. The disadvantage of this welding is that the position of the plug hole on the rear panel will greatly interfere with the storage position of the gas cylinder. All I can do is balance them.
Today, I found the iron plate removed from the previous modification cabinet, which can be used to transform into the side plate of the welding machine (it has been lost).
