- Feb 7, 2013
- 2,534
With some time this morning and the shop all nice and warm with the boiler working fine, I decided to do
a little repair work on a Stihl 038 chain saw I picked up at a garage sale. An 038 is a pretty decent saw
so spent some time on it a couple weeks ago cleaning it up and testing it out. The guy threw in an old
20 inch Oregon bar that was badly worn on the tip. Anyway with nothing better to do this morning I thought it
would be time to test out the small WP9 TIG torch and see if I could build up the damaged area with some
weld and grind it smooth. It went fairly well but I obviously need more TIG time. I was able to fill in each rail
without too much material to grind off. I used a 4.5 inch angle grinder with a thin cutoff blade to allow the
chain to pass freely once again. There was one spot that bridged near the tip so resorted to milling out the
groove with a .050 carbide end mill. Also I made a repair on the front of the saw above the muffler as
it had caught on something and looked pretty rough.
It's a little crude but will use the repaired side up on the saw. The bar was gouged out about 1/8 inch or so.
Here's the bar after grinding and milling out the channel. Hmmmmm, looks like I was a little hard on the tungsten! The red stuff is grease...
This is the repair on the saw above the muffler. The muffler had come loose and worn a hole in the orange plastic so I covered it up.
Maybe later on in the day I will see how the saw works with the repaired bar. It's a beautiful day up here, just right to cut up some firewood.
The present temp is 33F.
