A Chuck Backing Plate Journey
Robo_Pi
Feb 18, 2016
451
This took me much more than a day. In part because I'm only just starting out and had to figure out which tools to use and how to go about each stage of the process. So for me this was quite the journey. I took a lot of photos so grab your favorite beverage and sit back and hopefully enjoy the journey.
Prologue: I have a combo lathe/mill. It came with a 4" 3-jaw chuck. I just bought a 6" 4-jaw raw chuck for it and this is the story of how I custom made a backing plate for it. I also modified my lathe in the process. The original spindle only had through-holes in it and the original chuck was bolted on from the back side of the spindle. That has been very frustrating for me because those bolts were really hard to get at. So when I made this new backing plate I also drilled and tapped the original spindle so I can bolt everything on from the front. So that job is included in the following journey.
I began with a piece of 6" x 1/2" round steel plate that I bought on Ebay. The plate had been plasma cut so it wasn't perfectly round. I started by finding the center of the plate with a simple ruler center-finder and drilled a 1/8 hole for the new center. This would be my reference for the rest of the project.
289181
I then set the lathe up with a couple centers so I could stick this plate between the centers and spin it by hand. I also put a center punch in the tool holder to use as a scribe. The idea is to set the center punch up to the center of the hole pattern on the lathe spindle and then transfer that circle to the backing plate disk.
289182
I then put the backing plate between the centers and blued it so I could scribe the lines onto the plate. I did this for both the bolt pattern and for the chuck reference lip.
I did this all by hand without turning the lathe on. This was just my way to transfer these measurements without having to deal with actually trying to measure them.
289183
I then set up the milling head so that it was perfectly centered with the lathe center. And locked it down. Strangely this milling head doesn't have any degree markings so I just put center in the mill and line it up with the tailstock center.
289184
I then mounted my dividing head on the milling table. With the plate perfectly centered on the dividing head. I had to do some work to get that plate perfectly centered on the dividing head but I didn't take any photos of that process. But the following photo shows the dividing head being lined up with the center of the mill quill.
289185
I then put a center drill in the milling head and used the z-axis of the lathe carriage to move the center drill over to the bolt pattern line I had previously marked. Then I used the dividing head to center drill 3 equally spaced holes in the plate. The assumption being that the three holes in the lathe spindle plate are also properly spaced. :grin: And fortunately it turns out that they were.
289186
I then took the plate off the mill and over to the drill press to finishing drilling out the holes for an M8 tap. I couldn't do this on the mill because there wasn't enough room to get a drill bit in the milling head. The dividing head was too tall. But it wasn't a problem because the center drilled holes had already set the pattern.
289187
Finally I tapped the three holes.
289188
And now I was finally at a point where I could mount this on the lathe spindle. It's mounted here using the bolts that bolt on from the back.
289189
For me this was a major job just to get to this point. But it worked well. I now have the plate mounted in the lathe and was able to turn down the outside diameter to true it up.
289191
In the photo below notice that the back side of the plate is not flush with the lathe spindle. This is because there is a chuck reference lip in the middle of the spindle. So I will need to cut that reference next.
289190
And so I cut the chuck resister relief hole. I was careful to measure this as close as I could. I actually used the original chuck as a reference, and I fortunately got a perfect fit the first try. This will actually be the back of the backing plate when we're done here.
289192
Finally I faced off the backing plate just to clean it up.
Now we can turn it around and put it on the right way so the register relief fits over the resister lip on the lathe spindle.
289193
But first I decided to fit this lathe spindle so I can bolt things on from the front.
So back to the dividing head and milling machine. I could have done this the first time but didn't think of it.
This time I just drilled through holes in the backing plate. Again using the dividing head to space them evenly.
And thanks to my new ER-20 collet system for the milling head I was able to hold a drill bit with enough room to drill the holes.
289194
I then needed to have a register lip for the 4-jaw chuck. But I didn't want to turn the 1/2" plate down any thinner. So instead of facing it off to create the lip I found a piece of 1/4" thick aluminum plate and bolted that onto the backing plate. That process was a small journey in and of itself which I didn't take pictures of.
But here's the plate with the aluminum register lip mounted on it.
289196
I then turned that aluminum plate down to fit the 4-jaw chuck register relief. I just turned it down right there on the backing plate.
After I got that register finished I put the plate back on the mill again and used an end mill to countersink the bolts that will mount the plate to the lathe spindle. They need to be flush with the backing plate because the chuck will also mount up flush against the backing plate.
289197
However, before I can bolt the backing plate to the lathe spindle from the front I needed to drill and tap holes in the spindle itself.
So here I have the backing plate bolted on the spindle again from the back just to hold it in place.
Then I drilled through the holes in the backing plate into the lathe spindle. This way I know they'll be perfectly lined up.
I hardly ever actually measure anything if I don't need to. :grin:
289198
With the holes drilled in the hardened spindle (yes it was some tough drilling), I had to resharpen the bit quite a few times to get through it but I made it.
And then came the tapping of the holes in the hardened lathe spindle.
It took me 3 hours to tap them. An hour a hole. That's because I could only tap a few thousandths at a time. I had to keep backing the tap out and clean out the hole to tap another few thousandths. But I made it. I got all three holes tapped without breaking the tap. But it took a lot of patience.
289199
Finally! I can now mount things on the spindle from the FRONT!
289200
And so I did! Isn't that pretty? I really feel good about having done that. No more messing around with trying to bolt things on from the back.
289201
Ok, at this point I had to order some larger drills and taps for the chuck bolts. There are four bolts on the 4-jaw chuck and they came dangerously close to the holes I already had in this backing plate. But fortunately everything just barely cleared. I didn't take photos of that process. But I had to drill and tap the four holes for the chuck bolts.
And now I have a 6" 4-jaw chuck on my lathe. Yippee!
289202
This was one whale of a journey for me. It actually took me over a week to do this. Of course I wasn't working on it full time.
You can see the indicator in the photo above. This chuck runs out exactly 1 thou on the outside surface of the chuck. Not bad. Especially since it's a 4-jaw independent.
I also ran the lathe and it spins very nicely. I took it up to the max speed of my lathe which is 1600 RPM and it was still smooth as silk with no vibrations. So I consider this to be a success.
It took me a lot longer than I originally thought it would take. But then again, part of it was tapping out the lathe spindle so I can bolt things on from the front. I'll be forever glad I did that though. :grin:
Thanks for reading, and I hope you enjoyed the journey.
And yes, I know it could have been done more efficiently with better planning. But I'm still learning.
Unfortunately I'm at work and can't grab that beverage Robo , but that looks nice . Glad to here you solved that problem , nice work . :encourage:
Great job making do with what you have, and it's hard to argue with method when you have a good result. Should make you smile every time you change chucks. Cheers, Mike
Nicely done!
I think it's smart to mark by reference. When you measure, turn it to digits, then remeasure to transfer you can easily introduce errors thru poor eyesight, lack of attention, dyslexia, etc. Direct transfer of measurement avoids all that.
The only (slight) improvement I can see is to now open the centre hole in both the aluminum centre disc and steel backplate to allow longer items thru the spindle hole.
Great job!
-brino
Yep, that's in the plans. I haven't done that yet. In fact, I just ordered a boring bar so that will be my next project. My spindle is 3/4" bore with an MT3 taper. So I'm planning on boring this out to at least an inch or larger for clearance. I'll probably post a big jounry on boring that silly hole at some point. I have the original 1/8 pilot hole. I think I'll step drill it. 1/4", then 1/2", and finally the largest bit I have which I think is about 3/4". From there I'll use the new boring bar to take it to final size. See, I even make a big deal out of drilling a simple hole. :grin:
The one thing I want to make sure of during that process is not to accidentally run into the MT3 taper in the spindle and damage it. I figure I'll bore it half way with the boring bar, then turn the plate around and finish boring the other side. That way I won't need to worry about accidentally boring into the actual spindle.
Tough job but you prevailed! It isn't often easy to change major design features on a given machine- now you have a one-of-a-kind :)
mark
I'm going to try to drill clearance holes through the original 3-jaw chuck too so I can bolt it on from the front as well. It appears that there's just enough room to do it without hitting anything important in the chuck body. The only question is whether or not I'll be able to drill through it. I won't need to tap the chuck though so that's a plus.
And yes, it will be a unique machine then since it will now be designed "correctly". :grin:
Every time I had to take the chuck off I found myself cussing out the original designers. But they no doubt were designing around a chuck that had threaded holes in the back of it. But what a pain to get at those bolts. And with this lathe/mill combo you need to remove the chuck every time you want to use the milling head. Otherwise the chuck gets in the way. I have a hard time understanding how the original engineers didn't recognize that this would be a real pain to have to deal with. But such is life. At least it's fixed now.
James,
That was an interesting read and great photography as well! A 4 jaw chuck I would consider a necessity
and you will too for obvious reasons. Well done! :clapping:
Tonight I drilled out the original 3-jaw chuck that came with the machine so I can bolt it on from the front too. Unfortunately I don't yet have cap screws long enough to bolt it on. But I'll be ordering those tonight. :grin: And I'll be completely done with ever having to bolt anything on from behind the spindle again. There's no room back there to work. What in the world were the manufactures thinking? Apparently they weren't.
It just seems crazy to me to go through the trouble of designing an entire lathe/mill and not take the trouble to make sure it's going to be user friendly. Maybe they are secretly sadists? :grin:
