I need a bit a knowledge here.
the picture is of a 1/15 HP 110VAC gear reduction motor that reverses.
can I use a incandescent light control switch for speed control or do I need a "router" type speed control ?
next, do these small enclosed motors heat up bunches when they are run at low speeds ?
you can most likely guess what I would like to do with it. . . . but, without the above knowledge I hate to ruin it after making the necessary modifications....
