A 500v 16A switch transformed to Li-on battery charger!!!
petcnc
Dec 29, 2012
394
From that:
To that:
HERE IS HOW
Dealing with portable computers I found myself possesing alot of LI-ON batteries.
I like them batteries as they have high capacity (they store alot of energy), they have a nominal voltage of 3.7 volts per cell and they have a very slow rate of self-discharge, so they can be used in numerous applications in the shop.
They have 2 major drawbacks though: They are tricky to charge:
The Li‑ion charger is a voltage-limiting device that is similar to the lead acid system. The difference lies in a higher voltage per cell, tighter voltage tolerance and the absence of trickle or float charge at full charge.
http://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
They also need trickle charge (i.e very low amperage about 1/10 C) if the cell voltage drops below 3.0 volts.
To charge them properly you cannot use any DC power supply plug it in the mains and forget about it.
I was in search of a charger to be a) cheap, b) DIY and c) easy to make.
Mr Google drove me to the following webpage:
http://www.shdesigns.org/lionchg.html
The circuit presented there, although old, is very well documented and can be build from parts I already have in shop.
After some modifications to the PCB board (we always do! Don't we?) I printed the copper side of the circuit on paper.
As you can see I have cut a piece of copper board, I secured the paper on the copper side using masking tape, drilled all holes and using nail varnish I paint all parts needed to be copper.
Some 10 minutes in a Ferric Chloride bath revealed the copper side of the PCB
I know it is not pretty but it does the job!
After soldering the components I made some charging tests and it worked like a charm!
Now I needed a box to put it in.
An old 500V 16A switch inspired me
After removing all the guts I ended up with a very nice aluminium box.
A cleaning process using the fly-cutter revealed its beauty.
It only needed a lid.
A scrap aluminium offered it.
The lid needed some ventilation grilles that my mill managed to make using a small circular saw.
Some polishing and the necessary labeling and job done! The box is ready to accept the electronics.
Started by making a cut for the voltage meter and a hole for the charging LED
Then the PCB secured in place, the connectors drilled and placed and the wiring between all them parts finished.
Final test! It works as designed! I secured the Lid and I stood proud of my new tool.
I know... I have to replace those ugly bolts on the lid. But on the other hand it shows primitive and "hand made"
I cannot decide on that... its a hard issue..
Thanks for reading this.
Petros
PC140365.JPG PC140361.JPG PC150366.JPG PC140363.JPG PC140350.JPG PC150376.JPG PC140348.JPG PC140352.JPG PC140353.JPG PC140357.JPG PC140359.JPG PC150370.JPG PC150372.JPG PC150378.JPG
Nice job.
But it would be more impressive if you left the 660 V switch mounted on the wall and made a socket to just plug the battery in to. Can you imagine the look on your friends face when you took his flat battery and plugged it in to that! :rubbinghands:
Cheers Phil
Nice job.
Cheers Phil
Phil it can be done in no time!
I just have to replace the lid with the original one and support the switch underneath it!!!
Nice suggestion!
Thanks
Petros
Li-on battery charger Final touches
After my initial rush to complete the project, I left some basic functions and some details for later.
Later came!!! and I had to fix all the details!
In the design there was provision for two charging stages:
Trickle charge at 50 mA and
Normal charge at 500 mA
There was a jumper on the PCb for that but to change its position you had to remone the lid! Not very practical.
A switch on the front solved the problem
On the other hand the volt meter needed a cover to ease readings.
After that I think the charger is complete!
Not the prettiest you have seen but functional and safe to use.
Thanks for reading
Petros
