- Jan 28, 2011
- 3,584
I am going to build a new mirror cell for my telescope. It is a Newtonian reflector with a 13" mirror. A mirror cell is the support structure for the mirror. Without a proper support system a mirror would be distorted to uselessness. In using a program called PLop, one inputs the mirror data and the program will then plot out the positions of the supports. You can run the program several times and change the number of support points to find the system that works best for the mirror.
The distortion is very minute, like .0000125mm, which is 1/40 of the wavelenght of 500nm Green light. I started a design in Autocad using the information for a 6 point support system. The red triangle is 1" square tube and the small yellow bars along side are the supports for the mirror. One also has to align the primary mirror with the secondary mirror which is in this case 50" above the primary. The red triangle structure will have a fixed pivot, which is at the top and two adjustable ones on either side to collimate the mirror system to get good views through the eyepiece.
I include 3 files, a gif of the 3d drawing of the cell system and 2 plots for the results for the 6 point and 18 point support system. The 18 point is better but overkill except for one who is OCD. Note the small size of the numbers at the right side of the plots. TINY!
More will come along over the summer as I build this up.
Pierre
Pierre
