- Jun 18, 2014
- 3
Hello,
I have a Hare and Forbes AL-51G lathe with is very similar to the 9x20 lathe. A while ago I dismantled my saddle and apron in order to fit a DRO. I gave all parts a good clean and then assembled it.
All seems to work well, but I have a problem in that the longitudinal feed lever is hard to disengage while taking a cut. The deeper the cut, the harder to disengage. The lever engages very easy. I have again dismantled that apron and had another good look over every thing and and gave it a good going over with lubrication, however the problem is still there.
This lathe is only a couple of years old and I have had it since new, but seldom used. Sadly I can't recall trying the longitudinal feed lever disengagement before I dismantled it :-(
Any help would be greatly appreciated.
Thank you, Keith
Thank you, Keith
