Hi, my name is Rick I've been lurking in the back ground for awhile, A lkot of good information here. I hope someone can help me with this.
I was given a 9x16 hor. bandsaw by a friend, he couldnot keep the blade from running off the wheels, there is no name on the saw he doesn't know who made it either, but it looks just like an enco 9x16.
I totaly dissembled it cleaned and painted, there are 2 adjustments on the left side wheel to set tracking, I worked on that for about 2 days and finnally got the blade to track properly, the problem was the gear box driven wheel the one on the right was not parrellel with the housing, so I placed some washers between the housing and the gear box on one side and that fixed that, now the blade tracks properly and stays on the wheels.
Ok so here is the problem finnally. blade on , tension set, piece in clamp, motor running, , blade lowered in to the work, ( 1/2 x 6" plate ), the blade cuts almost half way across the plate, then the blade stops moving and the wheel on the gear continues to turn, if you don't turn off the saw the blade will run down and off the wheel. I've tried tighting the tension but that doesn't seem to help.I put another piece in and the same thing happened.
does anyone have some ideas, I've almost gone brain dead with this thing.
Thanks Rick
Thanks Rick
