- Jan 23, 2021
- 37
I am making a new collar to clamp around the quill on my 932v. I bored my first ever hole and I am not sure how to proceed. I am planning on adding a quill stop similar to Dark Zero , I am using a magnetic scale for the quill and have the tape mounted to the rear of the quill collar, and I am considering adding a traction spring to the mix also. My questions: 1. Should I make this a two piece or simple single split ring? 2. If I go to two piece route can I split the ring off center from the bore (red line in the pic below)?
A picture to get a rough idea of the placement of things:
*I am doing away with the small control box mounted on the left side of the head, it wont interfere with the quill stop.
