The surface was fly cut and the dimensions are 5" X 8". Got an idea for some attachments for it. In a couple days I will take some pictures of it in action.
I made it Suzuki. Its a piece of heavy angle iron with some gussets welded to the back. Then I flycut both surfaces, drilled and taped some holes and cut slots that my tee nuts fit into. In the third picture I have a stop bolted to the plate that in the future I am going to cut a vee groove into for holding round stock. Now I have to make an adjustable angle plate to cut the vee groove.
