Recently got my first mill, it's an older 8x30 knee mill that I'm in the middle of cleaning up. Trying to remove the quill that looks like this:
Top side with C retainer clip removed
Bottom side
On the bottom there are no holes to spin the bottom outer part off with a spanner wrench, maybe this was press fit into place?
So, is the quill supposed to come out the top or bottom? No owner's manual or even make & model for this so that doesn't help. Think the bearings may be shot because although it spins, it does so roughly. Could be dislodged gunk trapped in the bearings after soaking in Purple Power cleaner.
Any ideas? Thanks...
Bottom side
