Is there just not enough room (clearance) to hang the power feed for the x axis in the vertical position?
Like option #2 in pic below.
Seems like the option #1 is what you see configured for these bench top mills. My guess is in the vertical orientation you either won't clear your bench and if it did, you lose a significant travel once you get close to the base casting.
I'm my prep for the 833TV I'm trying to minimize as much floor space width as needed, knowing I will want power feed eventually. Just seems like the horizontal really takes up a lot of space.
Also, is it uncommon and unnecessary to have a power feed on the Y axis? PM only sells it with Z axis and X axis power feed options.
