- Nov 23, 2020
- 820
So I am in the midst of making parts for my Phil Vandellay belt grinder, and am at the table. I really want a nice flat table with a great surface finish, so I have decided to confirm tram. Before I did that though I wanted to check my Z-Axis gib as locking the head is spongy feeling. Lowered the head so the spindle nose is gently resting on a chunk of aluminum, and removed the gib. Stoned the back side of the gib to remove the raised areas due to locking bolt ramming into the gib at an angle, and decided to try something better. Ground down a brass rod to a matching angle, and bored out 4mm in the back. Machined the locking bolt to a nice slip fit on the brass grub, and have one more to go. Ill take pics of the second one.
If this does not help with locking feel, I am going to mill 2 landing spots into the gib at right angle to the locking mehanism, or do something with a ball nosed end mill and bearings.
Edit 2 - Scratch the ball nosed end mill Idea. Id lose gib adjust capabilities.
Edit 3 - OR wouldn't I...
