- Sep 8, 2019
- 4,392
I have an older Bison 8” 3 jaw chuck that requires 6 mounting bolts.
I went to the hardware store, and 3/8-16 does thread in okay, but I have a hard time believing that a *Polish* chuck would ever call for Imperial hardware.
I gather that M10-1.50 is almost the same as 3/8-16, but the local hardware store does not carry M10-1.50.
Do any of you know if Bison chucks have metric or Imperial female mounting holes?
I know that I *could* use the 3/8-16 bolts, & I have a 3/18-16 tap that I could run through the female mounting hole. Does anybody have an opinion on whether or not running a 3/8-16 tap through what could be an M10-1.50 female hole might spoil the chuck?
Note that 3/8-16 would be M9.525-1.5875 (compare to M10-1.50).
Some Googling on my part indicates that a 3/8-16 can thread in to an M10-1.50 nut (“it is loose enough & it fits”), but a 3/8-16 nut will not thread on to an M10-1.50 bolt (“too tight”).
