8° Lathe Tool Sharpening Fixture, For The Surface Grinder
Ulma Doctor
Infinitely Curious
Feb 2, 2013
3,957
I have been grinding and testing simple lathe tool geometry on different sized machines.
i have found 2 tool designs to have been exceptional, regardless of the lathe size. (from Unimat to 20x40 lathe)
the 8° and 10° designs i'm grinding have taken a beating in the name of progress, and have performed flawlessly.
i figured i would destroy a machine or 2 in the process, but this didn't come to pass.
Grinding smaller tools is no problem on my KMX10. (Deckel SOE clone)
But as the tools get larger, i move over to the Boyer Schultz surface grinder to make quicker work of it.
i have 10°,12° and 15° fixtures, that i use in my day job, so that's already taken care of.
i didn't have an 8° fixture, until recently.......
i have some 7/8" square 1214 that was dying to be useful, so it got the shoulder tap!
i portoband sawed off a 65mm length
i put the chunk in the Bridgeport and milled a 3/8"x .200" deep channel.
the rest of the work was performed in my home shop...
i'm a little more limited in my home shop, smaller machines (and lack of an appropriate milling machine)
but, no shortage of tooling or ways of doing things.
of that, i can assure.
I chose the Ammco 7" shaper as the go to machine.
its not fast, but is sure is cool to watch, and even funner to run!
My first hurdle was to find a way to hold the partially machined part in my shaper vise.
my first inclination was to pocket mill a hunk of aluminum to match the 8° pitch i'll need to surface the 1214 steel with.
then split the aluminum to have a clam shell type of fixture easily grabbed by the vise.
i pondered the idea for about 5 minutes, thinking about set up, tooling, time, & etc.
Then, it occurred to me, that i was under-utilizing a wonderful development tool at my disposal- the Ender5 3D Printer!!!!
my cad-Fu is very weak, but i managed to create a fixture, that i had outlined above, but instead in PLA plastic.
i used Tinkercad to make the template, then imported the .stl file to Cura 4.6.1
i used 35% plastic , cubic subdivision, 85/mm print speed and printed in the low quality mode.
it took less than 2 hours to design and print the holder i needed!
Technology is AWESOME !!! the bounds are truly endless!
The shaper made short work of the 8° angle in the 1214
i ground a tool i call the eagle beak.
as the name implies, the tool is formidable against steels.
there were doubts as to if the whole chunk of PLA was going to fail.
to my amazement i could not differentiate the cuts in this material,from being clamped directly in a vise.
i cleaned up the newly formed fixture and took some pictures.
the fixture is ready for the surface grinder!
Cool, I have some random chunks of steel laying around and a 3D printer.
I hope you don't mind if I blatantly copy your design for my use to.
I have been trying to think of an easy way to do this as my hand grinding skills are not so pretty.
Does the mag chuck also hold the tool into the holder?
Thank you! Please use the idea to suit your needs.
Between the depth of the channel and the magnetization, the tool should be held sufficiently, or so I would think.
Testing on the fixture begins tomorrow!
I think it will not hold the tool hardly at all, best to buy and modify a magnetic parallel, or use an angle vise to hold the tool bit. Or, use some setscrews to hold the bit in the present fixture.
View attachment 332282 View attachment 332283
View attachment 332285 View attachment 332284
View attachment 332286 View attachment 332287
Mike,
That is very cool and great work! Inspiring!
Evan
I didn't think the PLA would work, but it did!
my 10°,12°,and 15° fixtures don't have any sides to them, they hold tooling just fine with the mag chuck.
although not of conventional thought, this fixture traps the blank very well.
i really think this design will be superior to what i already have, that works great.
i guess i'll find out tomorrow ;)
