I picked up a Dayton model 5Z023 horizontal bandsaw to fix up. Some of the things it needs are: hand wheel for the vise, guide bearings, a band, coolant pump, feed cylinder rebuild.
I'm presently working on the cylinder. It looked to be ok, just didn't dampen so I replaced the two o-rings in the piston, and the one in the needle valve, and am filling it with oil.(let it sit overnight with fill plug at top)
The wheels (no tires on these) have a shoulder and the area the band rides is 5/8". Any opinions on what width band to use? The teeth on a 5/8" would only clear the wheels by the amount the band rides from the shoulder so I'm thinking a 3/4" ? The guide bearings are all 6202Z.
The piping for coolant is there but no pump. Any suggestions for low cost alternatives?
