Can any one tell how to remove the bezel from a 7A-S trav-a-dial? I suspect it just pops off by lightly prying it. However its not a bad idea to check and see if some who has one of these knows. Thanks
I looked at my 6 series travadial, and the plastic bezel just prys off; I used a pocket knife to do it, then looked up the parts catalog and it seems that series 6 and 7 use the same bezel.
Thanks for the response. The bezel did simply pry off. I was able to remove both the outer aluminum bezel and glass crystal, and inner plastic dial cover, clean them both, and finely be able to reed the dial. thank
