In addition to getting moisture uptake 7018 is a low hydrogen rod that loves amps. The general rule of thumb on 7018 is 1 amp per thousandth of rod, so a 1/8th rod is .125 diameter so it should be set to around 125 amps as a starting point. 7018 also likes correct stick out and stick angle, Keep a good tight arc with the rod as close to perpendicular as possible. 7018 that has been exposed for too long is darn near impossible to start, so crank the amps up some more and burn it hot and fast. Also a good hard look at the rod will tell you whether it is AC, DC, Low hydrogen, and moisture resistant. Lots of different flavors of the same rod. Good luck
Bob
