7" Atlas metal shaper - $1,100 (antioch, CA)
Interesting color choice for the little shaper.
No pulley on the motor, hmm. is it running? FYI
Oops, incorrect post
The motor pulley is on the other side Jeff. Under the cover you can see it’s there. What your seeing is they replaced the motor and it had shafts sticking out on both sides. Probably should have cut that extra shaft sticking out.
