6-inch depth of cut benchtop bandsaw?
Steve N
Oct 23, 2020
6
Looking for suggestions for a benchtop bandsaw for occasional metal cutting. Need 6-inch depth of cut. Not sure if something like this exists. I have a lot more bench space than floor space so a benchtop vertical bandsaw would be ideal.
There is a YT guy who used a cheap H and made a V.
I had a Rockwell band saw that I bolted a riser plate between the two halves. I then welded longer blades to fit. The Rockwell was a good saw, it had a back gear for steel and a faster gear for wood.
Cheers
Martin
Good to know....
