- Jan 11, 2021
- 7
Thanks for letting me join. I'm retired working on antique cars. I'm having trouble keeping the back gear engaged 0n my 6 inch atlas. Manually holding the lever it works well. What is the fix, new parts ?
That should be an Atlas.To be honest I'm not sure if it's atlas or craftsman. The motor is Dunlap Sears. Looks to be original. There is no decals or data plate to be found.
Boy a picture is worth a thousand words. knowing were to look and cleaning found everything but the ball and spring . A spring from a ink pen and a bb might just work. Thank youthis is easier to show than explain and I have my lathe in pieces right now so:
indent holes in chuck side of headstock
3/16 ball and spring in the inside face of the back gear handle
even properly adjusted, without that ball and spring the back gears won't stay in
