It's worth it for the X axis (cross slide). Less so for the Z axis (along the length of the lathe).The question is it worth $35 upgrade for 1 Ditron glass scale? I have a 12x36 Craftsman/Atlas lathe. Is 5um good enough?
Thanks
In practice 5um scales are more than enough for a lathe, even on the cross slide. They will give you 0.0004" resolution on diameter. 1um scales will give you 0.00008" on diameter. I can't hit anything under 0.0005" on my lathe unless I get super lucky, and in most cases when I get to within 0.001" I do a little happy dance. Anything better than that goes to my surface grinder for grinding between centers, and even then tenths are VERY challenging.The question is it worth $35 upgrade for 1 Ditron glass scale? I have a 12x36 Craftsman/Atlas lathe. Is 5um good enough?
Thanks
Thank you all.In practice 5um scales are more than enough for a lathe, even on the cross slide. They will give you 0.0004" resolution on diameter. 1um scales will give you 0.00008" on diameter. I can't hit anything under 0.0005" on my lathe unless I get super lucky, and in most cases when I get to within 0.001" I do a little happy dance. Anything better than that goes to my surface grinder for grinding between centers, and even then tenths are VERY challenging.
All of the above applies to glass scales. If you are looking at magnetic scales, 1um or 5um are "marketing terms" and have nothing to do with the actual scale resolution (which is around 10um for good ones).
Regards
Yuriy
Love your signature (both parts)I have 5um scales on my Heavy 10, more than close enough.
