5c Spanner Wrench
U
umahunter
Forum Guest
Register Today
Well I got a 5c collet block set and didn't realize it didn't come with a spanner wrench for the rear nuts so I figured I'd give it a go does anyone know of any dementions or plans to make a solid or adjustable can I use regular 1018 for the pin or should I use something stronger ???
I always use a hardened dowel pin for spanners.
Let us know what tools you have and we can give ideas on how to make it.
I bought an adjustable pin spanner wrench from Enco, and it works great, but they have discontinued it. Get the pin diameter and the O.D. of the nut and do a search for one. If nothing else, make one!
There out there if you want to buy instead of make one. Use dowel pins if you do other then that use what you have if you've got any scrap cut offs or what ever. I'd make one just to do it !
