- Mar 19, 2011
- 940
A few years back, I bought a 1988 Jet 4 x 6, used, for about $75. I only needed it for a small job in conjunction with my cabinetmaking business. So I struggled through the bad blade, missing handles, etc., thinking, "what a piece of garbage."
Fast forward to now. I'm getting the metal hobby shop going, and finally got around to taking a look at the saw. New blade, readjusted and lubed the bearings, fiddled with the guides, etc. It cuts pretty nicely, so it's time to do the mods. I've put on new wheels, and replaced the vise screw handle. I think the extended jaws and cut-off stop are next. Then, maybe the flip table. And now I'm thinking, "it ain't so bad."
I finally opened up the gearbox, and took a look. What is supposed to be in there? Mine is about 1/3 full of a heavy, brown grease. It's what we called "bear grease" when I worked in a bicycle shop, 45 years ago. The worm and the gear were well coated, and I've never heard any odd noises. (When I do, I use the Car Guys' method of dealing with them: I turn up the radio.)
Also, there is a fairly large mess of casting slag in the cutoff slot. It doesn't interfere with anything except my sense of esthetics. What would you suggest as the best way of cleaning it up?
Have I missed anything critical? I've looked at the bandsaw mods page, and gotten a few ideas. I'm certainly open for more suggestions.
